Craigpump
I use poly pipe in my 60 foot well. When I pull the pump I don't lay the poly down on the grass, I lay it onto sawhorses. I also wash it with bleach as I am setting it back into the well.
I see a lot of pics on this forum with hundreds of feet of PVC or metal pipe laying in the grass so it would seem a lot of installers are not too concerned about contamination or they wash them one by one as they set the pump.
I use standoffs to keep the wire from chafing against the casing and I use a torque arrestor to keep the pump from flailing about. Mind you I have a 6 inch casing so not worried about little bits falling off and jamming the pump in the hole.
I would be more worried about the pump unscrewing itself from the PVC pipe or the PVC cracking and the water recirculating until it got so hot that the PVC melts where it goes into the pump and the pump falls off, pulls apart the crimps and is lost in the bottom of the well.
In almost 30 yrs I've never, ever seen a pump unscrew off of PVC pipe, nor have I ever seen sch 80 crack or split while installed as drop pipe. Split couplings we see on occasion, but stop and think that our average well is 300' deep, holds about 450 gallons & the water temp is 52-54 degrees. I seriously doubt that you could raise the water temp high enough to deform the pipe. As for crimps pulling apart and losing a pump, if you put your torque arrester over the wires, you won't have that problem. Last month we pulled a 1hp-5 that melted off due to running dry in a dry well, the pump came up because it was installed correctly.
