Dealing with a basement toilet that has 3” pipe leading to the ejector. It had a 4” PVC flange around it that the toilet sat on. The issue is that they concreted around that flange and I’m unable to get it out on the sides. I’ve seen in the past that there was discussion about a flange sitting inside of the 3” pipe but I’m not sure how well that worked out? Obviously the amount allowed down that opening will be greatly reduced. I don’t know any other way of doing other than ripping out the concrete around the flange and attempting to remove it without damaging the drain pipe. Basically, are there any flanges that fit INSIDE (not yelling, just exclaiming) the 3” pipe? I’ve only found them that go outside the 3”. Any thoughts?
thanks
thanks
