1987 Moen Shower Valve
rcspott
MT
Just bought a home that was built in 1987. Shower has a Moen valve. When we use any other sink/water in the house shower water temp changes drastically. Can a new stem convert the valve to a Posi Temp/Pressure Control valve or does the whole shower valve need to be updated? Thanks
KaeEdwardPlumbing.com
Sugar Land, TX
Hello there,
For clarification: I'm not certain what "water temp changes drastically" is meant to imply. Is this Hot water, or Cold water that you're losing?
How many Fixtures do you usually turn on for this effect to happen & does it require your Moen Valve in use? Can you use other shower valves in your home without issues?
rcspott
MT
While showering if someone else in the house uses water the temperature of the shower water changes. The water gets hotter if someone uses the kitchen sink. In 1987 had Moen come out with the pressure balanced valves?
In 1987 you most likely have the old Moen valve that was not balanced. I would replace the valve, not the cartridge.
In my mothers home I replaced all three. Nothing worse than standing in a 36" x 36" shower while someone uses the kitchen sink in the other room, cold, hot, cold, hot. Nope! I'm replacing this with something pressure balanced.,
Without touching the shower valve, you can make sure there is an expansion tank for your home. That also helps with pressure drops.
