Russell Harris
Hello,
I have a 1952 cast iron drain setup for a hall bath that uses a wet vent from the lavatory for the tub. In the picture below, you can see that the lav drain runs about 3ft back towards the tub then turns back into the 2" drain that is running from the tub. The cast iron is failing and weeping on the lav and I'd like to replace with PVC, plus raise the drain from the tub up off the dirt.
My question is do I need to recreate the 3' run back towards the tub for the lav drain? Or can I just raise everything and have the lav drop into a wye right at the good 2" cast iron before it goes into the 4"? Does the run back towards the tub somehow make the wet vent better?
Thanks for any advice!
RH
RH
