Baseboard Heater Clearance
ohtara1211
I just tried to install a Toto Drake ADA toilet on a twelve inch rough. To my surprise it would not fit because the base will not clear the baseboard heater in back of the toilet like the original did. My contractor said I needed to buy a "high clearance toilet', but my local plumbing store looked at me like I had two heads. I guess I could go to a ten inch rough, but that would push the toilet out 2 more inches.
Does anyone make an ADA toilet where the base does not go as far as the back of the tank?? Thanks, Jeff
A heater behind the toilet?
You might try the Gerber 21-318
or Toto Dalton CST734F
Or perhaps the American Standard Cadet 3 which has space behind the bowl.
Melting wax ring.
I was wondering if a heater or any other heat source that is very close to the toilet and/or flange might have a very good possibility of melting or at least severely softening the wax ring.
Is that possible? Does that happen?
Just a thought. Thankfully I don't have any heaters near a toilet (seems like a sanitary problem too- splashing, bad-aim etc)
Back
