Terry Coen
Thanks to all for help and support on my well questions - I need one more bit of advice.
As stated in an earlier post, I have a 2” well casing with a 2-pipe jet pump adapter that was buried about 5’ deep and 10’ away from the house. The well is about 30’ deep. I want to replace the old galvanized down pipe along with the pipes feeding the pump in the house. The old drop line is out and as a result of some great advice from this forum I have decided to go with the 1" schedule 80 pipe and special adapters; this seems like it will be the easiest to work with in the cold weather.
My problem (or question) is that I intend to place the new drop line set-up into the well and run the new lines into the house this week-end but won't be in a position to Prime and test the system for a week or so because I am also in the middle of insulation and furnace work inside the house. I will not have that all complete for at least a week or so, so freezing water, pipes, pump, etcetera, would be a problem. Unfortunately, I need to need to get the hole back-filled and return the expensive back-hoe this week-end. Sooooo - with all that said, is there a potential problem with the leathers not swelling up and sealing properly since it will be a while before I actually prime the system? Any thoughts or suggestions? Thank you all again for your great advice - much appreciated!
