OK... here goes.
Subject is our upstairs bathroom (3rd of 3; other two on main floor). Toilet has never really flushed right (even with just water), although the sink and tub both drain fine. Doesn't act like clogged, but bowl fills up and drains very slowly (may flush ok a couple of times after whole system has been sitting for a few hours). I have always suspected faulty design (not enough slope to horizontal runs, too many turns, insufficient vent?). Drain pipe for that bathroom runs about 10 feet horizontal, then down to first floor, then into main horizontal (under slab) drain to the septic tank.
Original toilet was generic. A couple of years ago, in an attempt to solve the no-flush problem, I installed an American Standard Cadet3 RightHeight Elongated (2.13" trapway / 3" flush valve / MaP 1000 gm / 1.6 gpf). However, new toilet did not help! So I then installed the new toilet in our master bath downstairs, and soon found it was a VAST improvement over the original toilet; zero need for plunger vs plunger about half the time with old toilet. So the problem upstairs seemed to not be a mediocre toilet.
Later had a plumber confirm the first horizontal drain line for upstairs bathroom holds about a 1/2 inch of water due to insufficient slope, and our main drain tube (under the slab) also tends to hold some water for the same reason. Stupid homebuilder.
So anyway, the plumber recommended a pressure assisted toilet for upstairs. Do you think this might work, given a high quality pressure toilet and sufficient water pressure??
Thanks for your help.
