Where are the vents?
Yinn
NJ
It started off with just doing some demo, and it turned into question marks. This is a double vanity, and based on what I can gather it may not be piped appropriately. The sanitary tee in a horizontal position was a tip.
Sink 1: 1.5”
Sink 2: 1.5 x 1.5 x 2.0 Sanitary Tee
Vent Stack: 2”
I was under the impression that each trap requires a dedicated vent. This would seem to me as it’s sharing a vent. Am I wrong?
It’s a first floor bath, with full basement access. The wall is a load bearing exterior wall, so there are limits on how much I can drill out, but I was thinking about adding a 1.5” pipe like this to allow venting. Hoping for a sanity check before I proceed.
And of course I have to cut out and replace the sanitary tee with a wye.
Yinn
NJ
Wouldn't that just make it a horizontal wet vent?
That was my impression as well. The best guess would be that you can’t have a set vent be the dry vent?
No matter what you do for venting #1, #2 will NOT be vented because the other one drains past its connection.
There has to be some way to replumb this so it works right? I guess I could look into aav if not.
This could be one way. There are other ways. The wye could be a santee if that fits OK. The right-hand trap adapter could also be a santee, and get rid of the existing santee. The right santee with trap adapter would feed into a combo, and its waste would join the other drain.
OLD TIMER
FLORIDA
its that easy.
OLD TIMER
FLORIDA
You've created an s-trap.
Are you referring to my picture with the pink line? The pink is a drain line from the left trap adapter, which is on a new santee. The yellow arrows represent a vent line into the top of a new santee . That was already present in the drawing that I marked up.
The traps will be outside of the wall. The right-most trap adapter will be vented at the existing santee.
I presume the vent line on the far right is dry until the santee.
OLD TIMER
FLORIDA
My mistake. now I see what your doing. my eyesight's not so good.
