When to replace a working toilet?
JoeJee
HVAC Contractor
Arkansas
My house has two toilets that are stamped 1983. They seem sturdy and don’t have many issues with clogging. They are off colored a bit and could use new seats. Is there a time recommendation on toilets or is it more about when they finally break you replace? I ask because I will replace eventually because I am looking to have a cleaner look but it got me thinking about the topic.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Depending on water conditions, often the trapway develops mineral build up, which causes poor flush performance.
And, tank to bowl rubber gaskets sometimes deteriorate and need replacement.
And, where water is not plentiful, modern toilets that use 1.28 g.p.f. help reduce consumption.
A few factors:
- you no longer like the look
- it doesn't work reliably, and isn't economical to repair
- you live where you pay for water and sewer and or there's a shortage, and thus, higher costs
Many of the toilets from that era didn't work all that well. Newer designs, at least many of them, can flush well with less water, so especially where water is scarce or expensive, a newer one has advantages.
