Wet bar drain
Paul Spindy
Pennsylvania
I am hoping to put a wet bar in the sun room to the left in the picture. Not sure if I can have the number of 90 turns. The sink drain will come out of the wall on left and turn 90 to corner with another 90. It will flow to a sanitary tee where the vent is located. I will use 1 1/2 pipe but can put 2 inch if needed. This will only be used to rinse glasses. Thank you for you're time.the wet bar will be on the other side of the wall lower left
