mrboardboy
We removed the original jetted (& enclosed) tub only to find the 1 1/2" drain vent jogs out of the wall and thru the floor and connects to the 2" drain line. We would like to redirect the vent thru the plate and below the floor, turn 90° thru the adjacent floor joist then another 90° and re-connect to the end of the 2" drain line.
Our new tub has a center drain (tip of red pen, lower center) with a proposed route that would connect to the 2" drain line thru a reducing wye about 8" downstream of the vent connection. The double lav drain is vented separately and joins the 2" main about 5' from 1/4 turn. About 8' further the 2" drain connects to a 3" vertical drain.
The entire tub area is cantilevered left of the 2x6 stud visible in the photo.
I have also included a 3D model of both existing and proposed drain systems for reference.
It is physically doable, but is it code worthy?
Thanks in advance.
Thanks in advance.
