Well water ph question
Truckermatt
Howards Grove WI
New user here.
I have well water shared with next door house. Well pumps. I have an old acid neutralizer (water care) brand and matching softener. I am replacing the softener and wanted to know when size to get for neutralizer ( which is leaking a little )
This was all in the house when I bought it 5 years ago.
Question is last year I had a water lab test my water for baseline results. And I know I have hard water but also have a ph of 6.46
When I used 2 different brand test kits I came up with 8.5 ph both before and after the neutralizer
How can the ph change it a year?
Any thoughts
If the water is shallow, there could be effects of changes at the surface. Otherwise maybe your test kit is old or something? What pH test kits are you using?
That is a surprising swing, as you know.
Time for a new test of your water? I like kit 90 from http://www.karlabs.com/watertestkit/ for a lab test. Is that who you used last time?
If you care about the coliform test results, care needs to be taken in
sampling. http://www.ugra.org/pdfs/SamplingHandout.pdf is one description
of a method to avoid contaminating the sample.
ditttohead
Water systems designer, R&D
Ontario California
pH is easily influenced by many factors so changes in pH are common and expected. Agree on the test, time to get a new test done. if your water has changed... which water tends to do, a new test is a good idea.
NTL Labs or Kar Labs are both excellent options.
Truckermatt
Howards Grove WI
The test from last October was from a certified lab. And the two recent tests were kits from a pool supply store.
I will probably just replace the neutralizer since they had one already I am sure they needed it
Bannerman
Ontario, Canada
If conditions have changed, you need an updated comprehensive test to know what you're dealing with now so as to establish the appropriate treatment methods currently required.
Once updated test results are received, post those and the results from last October as a comparison.
Edit to add: Since the well is shared, is each homeowner performing his own treatment or is there any treatment performed prior to distribution to the two homes?
Truckermatt
Howards Grove WI
the neighbor who share the well with me has the same test result i have with my test kits... they only have a water softener in there house. but they say they cant drink the water because of the taste.
Truckermatt
Howards Grove WI
Just an update, I just got the water tested for ph level at the lab. Last year the ph water 6.46 now the water tested at 7.33 ph
That's nice to see.
Nice. You might want to get your own pH test. I have Hydrion (O67) Urine & Saliva pH Paper 5.5-8.0. I found that it took a few seconds to get the color I expected rather than the right color being instantaneous.
You might find some test that is better.
