I recently pulled the trigger and finally installed a downflow calcite filter in my home to address my 5.9 ph water.
My biggest concern with such a system has always been the wasted water when backwashing.
My well is only 100' with my static water level at around 75'. That's only about 112 gallons of immediate water in the well pipe. Without having any idea how quickly ground water flows back into my well when the water is used, I worry that the approximate 60+ gallons simply dumped upon backwashing will leave me in a bind.
My solutions are this:
1. It has me thinking that it would make more sense to reclaim the backwash water, which is clean, and run a connection BACK to my well head so i wouldn't lose a drop. Is this unreasonable to consider or technically even allowed?
2. Simply backwash less often like every 10 to 14 days. Since the water is clean, backwashing only seems to be to prevent compaction and channeling of the media in a downflow setup.
I've seen a lot of conflicting advice online on how often this is recommended.
My pressure gauges at the well pressure tank and after the calcite filter are consistently within 3 psi of each other even with 10+ days between backwashing. I've been testing this.
3. Abandon this system completely and research/install a soda ash system instead.
I'm actually leaning this way if i don't feel comfortable with wasting precious well water.
My water obviously got harder with the calcite filter but a water softener still feels optional. i went from 1.1 grains hardness to about 7.
Still i can't help wondering If I've simply traded one problem (low ph) for another (hard water).
Am I worrying un-necessarily? This really seems like a LOT of water to just throw away and not reclaim somehow.
Appreciate your thoughts.
-Tim
-Tim
