Well pump starts but won't run
Michael Gibson
Indiana
When pressure drops below 30 switch kicks on and pump will come on for about 3 seconds and quit for about a minute then repeat process. This will continue until pressure reaches 50 psi and switch opens up.
I have changed switch, and checked pressure tank
ThirdGenPump
MA
If the switch is opening during this you have an issue with the tank accepting flow. If the switch stays closed you have a motor issue, it's not switching over to the running coil or it's triggering a thermal overload.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Like Third gen says, if you have a control box the capacitor and relay maybe bad. If you do not have a control box the overload in the motor is tripping, which most likely means you need a new motor.
