Well pump sizing and replacement
ivantk88
I'm trying to figure out a replacement for my Jacuzzi hurricane model T5HUR8-92 1/2HP PUMP.
The well is aroind 300' deep other specifics I really don't know thanks in advance .
Ivan
ivantk88
this is an 8gpm pump the model you listed here is way outa my price range
How big is your well casing? In common home pumps, some are 3.75 inch effective diameter, some are 3.9 and some are 2.9....
The Franklin class J (the J is from Jacuzzi) is one of the 3.75 inch pumps. They make 1/2 and 3/4 HP 7 gpm pumps in that size
Your water must be very close to the surface. Did the old pump provide plenty of pressure?
ivantk88
Ithink its a ten inch I can see the water not very far down at all pressure was fine with small pressure tank .
You will have a lot of flexibility. How far down would you estimate? You may be able to use a 1/2 HP 10 gpm pump.
index.php
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
That pump has a max head of 200'. It will take at least 138' of that to make the 60 PSI for the pressure switch shut off. That means if the water in your well is deeper than 62', that pump does not build enough pressure to work. Big difference in a 12 GPM and a 7 or 8 GPM in a 1/2HP.
