pump is about 15 years old, tank is about 11 years old. I have turned off various faucets and outlets, can not find any leaks, but I can hear the pump run intermittently every hour or so.
I did tap on the tank, bottom is dull sound and top pings. I did release air from the tank and it did not have any water come out.
i can not find any leaks anywhere. the gauge inline from the well before the pressure switch never moves, when water is flowing, not sure if that is an issue or not.
I was thinking about replacing the pressure switch as a first step.?
any advice is appreciated.
tia
i just checked the pressure in my air tank and it is 52 psi and according the the label it should be 38 psi.
should i let some air out?
tia
