I posted about 18 months ago regarding low pressure in my new house. The attached diagram shows the current setup on my farm. We are now planning on wiring the pump to be connected to the new house so that it can be connected to the backup generator that way we can also maintain water to the barn and cabin should power go out. We planned for this when we built the house and already ran conduit underground with rope so we can pull the electric wire through. With this change, the pressure tank will now be in the basement in the house. The set up is currently, 1 HP - 15 GPM pump set at 130 feet deep. Well is producing 45 GPM. The elevation change from the well head at grade to the second floor in the new house is about 50'. From pump head to new house is 400 feet. 1 inch water line from well to house and well to barn/cabin.
Questions: What is the recommended pressure tank size and pressure switch size? Right now the pressure tank in the barn is 70 gallon with a 40/60 switch. I have been advised to do a 60/80 switch and 80 gallon pressure tank, but wasn't sure if that would be too much for the house or if it would be needed to overcome friction loss with the 400 feet run. It was also suggested to put a check valve at the well head. I have talked to a few local plumbers and well pump companies and get conflicting advice. Any thoughts would be appreciated. Thanks!
