Hey guys! I have been around wells all my life but this house I am in now is my first with a "complex" well setup.
I have a 59' well with a standing water level of 5' below ground surface. The well put out 5gpm when it was drilled in 2006. This feeds a 1500 gal water tank. At the wellhead there is a check valve as well as 5gpm dole valve (to avoid pumping the well dry)
Today I heard my tank filling so I walked over to where my well head is to make sure things were running correctly and good thing I did. Half the yard was flooded. After removing the fake rock cover I found the well was leaking badly. After killing power and cutting off the insulation I found there was a PVC joint that had failed. This joint obviously done half-ass to start with, less than 1/2" of pipe was in the joint and no primer was used.
Anyway, I got some replacement PVC pieces and replaced. After allowing the cement to cure I tested it and it all held pressure, but now appears to be making a noise. It sounds like a mixture of water flowing and air flowing to me. I let the well run for 30 minutes (until the tank was full) and the noise stayed pretty consistent the whole time. Flow seems fine on the tank end, same as before. I did remove the union (and thus remove the check valve) when repairing but I would imagine any air should have worked its way out by now?
Prior to this all I could hear was the well motor running, but I'm not sure if the insulation plus cover may have been muffling the water noise (I never observed it run before with the cover/insulation off). I'm linking to a video- what do y'all think?
