WApple8
Ive read on some of these forums of an ongoing issue with WM boilers and their heat exchangers.
My boiler was installed in Oct of 2010.
All was fine until recently. (last year)
My issue is my boiler is fine in the summer when only used for hot water.
In the winter when the heater is used, and the heater runs, the pressure in the system spikes above 30psi, and blows the relief valve.
I’ve adjusted the Taco 329-3 valve to compensate, and made sure the expansion take pressure is correct, and as of now all seems ok.
I have hard water with a water softening system.
My question is-
(With a history of problems with the WM boilers),
Is there a major problem coming down the road that would cause the heating system pressure to spike, and I should be aware of?
Thank you.
My question is-
Thank you.
