CoHotelier
Symptom:
The prv (Watts LF25aub 1”) howls or sings loudly when it’s opening and closing, but not during the flow event (toilet, shower, doesn’t matter). If I throttle down flow at a hose bib, I can get it to howl/resonate continuously at very low flow.
System Details:
The building has 4 rooms, each with sink/tub/shower/lav. It is a standalone addition to our motel, so quite often two or three - and potentially four sets of fixtures could be running at once.
Incoming town line pressure is 175psi as shown on our nearby fire system gauge on a dedicated 2” line. Domestic 1” Ts off of that line outside of the building.
The incoming domestic line is 1” with a 1” Watts LF25aub PRV followed by a Watts Reduced Pressure Backflow Preventer.
I’ve had the PRV open, no obvious defects, and screen isn’t clogged at all.
Grabbing, adding mass, tension, etc to the PRV makes no difference
I did add an expansion tank on the system near the domestic hot water heater to remove any home-side back pressure concerns, however I don’t think internal line pressure from expansion is a problem as the PRV is noisy on both opening and closing… I don’t see how line pressure build up from heated water would act fast enough to cause a problem on close, or after a full flow event… plus it’s all behind a backflow device.
Adjusting pressure up and down seems to have an erratic, but not reliable effect. If I crank the pressure up I can get it quieter, but not silent, and not reliably quiet. Even at near 80psi it can still be noisy, it’s erractic.
I’ve got a couple potential reasons this is happening as I see it…
Solutions are…
Thanks all for any attention you can give this.
System Details:
- Outside pressure at 175psi throttled down to 60psi is too big of a drop at very low flow conditions (opening and closing) for the prv.
- The PRV is oversized at 1” for the four bedroom unit and is outside of its ideal operating conditions trying to handle high pressure and very low flow.
- The PRV is faulty (it’s six months old, but the noise started immediately upon install).
Solutions are…
- Buy a rebuilt kit for $50 and see if that fixes it.
- Replace it with a new same unit, Watts 1” (Logic being even I used a rebuilt kid there could be something wrong with the hard parts or the cast of the original unit that a rebuilt kit wouldn’t address and it’d be a wasted $50 and time). Same unit would ease install effort.
- Replace it with a new same brand/model lf25aub unit, but in ¾” instead of 1”. A little repiping but nothing crazy.
- Replace it with a different brand 1” (I had looked at the 1” Caleffi 535 series with gauge, but not sure it’s right for my application).
