I want to install a water softerner. I can see the Shut-off valve going into my house. One problem is that it is located on the right front corner of the house. (I want to keep it out of view). The other is that the Sears installation guide does not recommend installing it outside due to the electronic components unless you build a cover or shed. If I install it inside my garage it will only soften the hot water and the cold water going to my two showers. All the other cold water will not be softened.
Do you recommed the installaton inside the garage or the one outside? And if I install it inside the garage will this be an acceptable installation?
