City water or well water? Chlorinated? I expect well, but chloroform number caused me to ask. You got tests for more stuff than I am used to seeing.
Chloroform A disinfection byproduct frequently found in a chlorinated water. 47 ug/L
I am not used to seeing that tested for. The level seems low enough.
Corrosivity,Ryznar Index A measure of the water's tendency to corrode metal or form mineral scale. A value greater than 8.0 indicates a tendency to corrode, and a value less than 7.0 indicates a tendency to form scale. A value near 7.5 is neutral. A thin coating of scale inside a metal pipe may help protect it from corrosion. 9.0 S.U.
Try to use plastic pipes.
Hardness (gpg) 8.0 grains/gallon
You would benefit from a softener. 1.5 cubic ft of resin in a 54x10 tank is a nice size, and it could serve several people in the house. Salt usage would be low. It would take out hardness, iron, and manganese . Your iron, and manganese numbers are pretty low. It's not urgent. I would also use a big cartridge filter, even on city water. It not only catches solids, it serves to detect solids. A bypass on the filter is good. I don't have that, but I do keep extra o-rings.
I am not a pro. Maybe there is something that I missed, but your water seems very good. A softener would improve it.
