C - 32
H - 10 (should this be lower?)
C should be lower, but DO is usually going to be the overriding number.
Usually you make BD at least 60, tho there could be some tweaking. If you are short on water and want to minimize BD, what color is your injector?
System info (not programmed)
salt lb/cuft = 7.5 ; A choice ( efficiency vs capacity)
BLFC = 0.5 ; Brine Refill rate GPM
cubic ft resin = 1 ; ft3 resin = (nominal grains)/32,000
Compensated hardness = 8 ; including any compensation
People = 1 ; gallons affects reserve calc
Estimated gal/day = 60 ; 60 gal per person typical calc
Estimated days/regen = 45.91 ; Computed days including reserve
Fleck 5600SXT Settings:
DF = Gal ; Units
VT = dF1b ; Downflw/Upflw, Single Backwash
CT = Fd ; Meter Delayed regen trigger
NT = 1 ; Number of tanks
C = 23.0 ; capacity in 1000 grains
H = 8 ; Hardness-- compensate if needed
RS = rc ; rc says use gallons vs percent
RC = 60 ; Reserve capacity gallons
DO = 14 ; A guess. Day Override (28 if no iron)
RT = 2:00 ; Regen time (default 2 AM)
BW = 5 ; Backwash (minutes)
Bd = 60 ; Brine draw minutes
RR = 5 ; Rapid Rinse minutes
BF = 5 ; Brine fill minutes
FM = ____0.7 ;
https://terrylove.com/forums/index.php?attachments/img_fleck5600sxt_flow-png.31592/
The less salt per cubic ft, the more salt efficient, but more hardness breakthrough.
Revised based on number from
https://terrylove.com/forums/index.php?threads/help-for-programming-fleck-5810.82673/#post-595983
BLFC = 0.5
cubic ft resin = 1
Alternative C and BF pairs:
lb/cuft ; C= ; BF=
6.000
; 21.0 ; 4
7.500
; 23.3 ; 5 ;** used in above... slightly different C here, but close.
9.000 ;
25.2 ; 6
10.500 ;
26.6 ; 7
