Watersoftenerhelp
6" well casing, 78 feet deep well (100GPM capacity) constant pressure goulds 2HP controller, 33GPM well pump.
Water softener: 3CU, autotrol 268 with 760 timer.
Well pump supplies water for my landscaping.
I have been facing a problem since i've purchased this home. One of my biggest problems is when a faucet or anything not connected to the softener is running. The water softener senses flow and the icon for water appears on the screen. Which seems to pop on and off and wastes unnecessary gallons of water (with my geothermal running it wastes about 1 gallon every few minutes). I ended up having a spring check valve installed and that seemed to solve my problems for the winter time.
Summer time is now upon me. I have turned my sprinkler system on and time to water my beautiful grass. Everytime the zones would change i would have an build of pressure and my system would backflow. Causing extreme water hammer. I mean my house seemed like it was going to fall apart.
I had the check valve removed from the water softener so i was able to water my yard.
Now my issue is, every time the zones change or is running. I can hear water sloshing back and fourth in my water softener pipes. This is causing major hissing and backflowing inside the water softener head. Which sometimes vibrates the flapper valves very loudly.
When some of the bigger zones change, my pressure gauge will be at a steady 68PSI to dropping to 50PSI and when it changes to another zone, sometimes it will end up going back up to the 70PSI range. All my sprinklers still work great and my house pressure is great.
Is this just happening due to fluctuation with my water pressure? Causing the backflowing and hissing inside my controller head?
How do I fix this, was my softener incorrectly plumbed? Is it due to a constant pressure well pump and backflowing is kind've expected? Should I remove drywell where my softener is installed to see if it was hooked up too close to a cross section?
