wwhitney
All of your data so far is consistent with (a) a check valve (or PRV or the like) between the outside hose bib and the water heater and (b) pressure increase from inadequately addressed thermal expansion. And (b) could be either a non-functioning or undersized expansion tank, or the water heater going nuts and overheating the water, like a thermostat failed closed.
Of course, that doesn't explain the 3:00 a.m. timing. If it's just approximately 3:00 a.m., then it could just be consistency on when your last hot water draw is, and the excess pressure taking 6 hours or whatever to build up. But if it's exactly 3:00 a.m. then there must be some timed effect occurring.
John's theory of the municipal water pressure spiking at a consistent time in the night is promising. But if it only spikes to 90 psi (per the one night's reading at the outside hose bib), I don't see how that could directly trigger the T&P. It could raise the baseline pressure to 90 psi, and subsequent uncompensated thermal expansion could get you to 150 psi. If the timing is consistent, that's possible.
Cheers, Wayne
Cheers, Wayne
