isabelle
Hello,
Thank you for adding me to the forum. I have been trying to figure out our tap water situation (Lexington MA). A few weeks ago, we had to replace a water recirculating pump that was only a few years old, but that had seized up apparently due to a white deposit inside.
I've had 2 local water analysis companies test our water, yielding different results. The first gentleman found high ph (9-9.5), hard water at 4-5ppm, and high chlorine ("levels like would be in a swimming pool"; the solution from Hach turned a deep pink color if I remember correctly). He then called the town for more information and learned that they use chloramines for disinfection. When he called me back, he told me he did not know of a truly effective way to reduce chloramines, and that the carbon backwash system he initially recommended would not work. Also, that the presence of chloramine would 'clog' the carbon filter and also make it difficult to reduce the hardness. [Since then I've read a lot of threads on this forum that essentially seem to confirm this, but that also identify 'catalytic carbon' as a solution.]
So I then invited another company, assuming they would find the same results and hoping they would know about chloramine solutions. However, their results were hard water at only 1ppm and slight chlorine elevation with the same Hach test (slightly pink which he said would be about .2-.4 chlorine). This gentleman thought the level of hardness may not justify a water softener. For the chloramine, he would recommend a coconut carbon (not sure what that means).
So, I am really confused and not sure what to do next. I have ordered the Hach chlorine test tube kits to run a few test-retests myself. I would also love to know if anyone on this forum could recommend someone in my area who is known to be good.
Thank you in advance.
Isabelle
Isabelle
