KineticoUser
- Messages
- 189
- Reaction score
- 3
- Points
- 18
This control valve is rated for 24V. My original power transformer burnt out. I have two others to choose from. I used a 16VAC which measures at 17.25VAC, and everything worked fine for about a year. Now, I find it apparently doesn't open the valve enough to allow the water to reach the higher emitters. I can switch this to a 24VAC which measures at 29.25VAC, but I fear that will exceed the 24V this controller is rated for. Is this a power issue or a diaphragm issue or something else? If I open the vacuum breaker, I get plenty of pressure to reach the higher emitters. I'd like to understand the mechanics of this... not just hear recommendations without the education. What are your thoughts on this?
