I tried to stay away from the trees as best as I could. I couldn't believe the oak tree roots had just completely encased the fittings like a sock. One was more than 100' from a tree in any direction. I hope the salt trick works.
You don't have a pump so you don't need a CSV. And the city is only giving you 80 PSI, which then has to go uphill and a long ways. So I would not install a regulator of any kind. If they don't have a backflow preventer at the meter, then you will not have to worry about thermal expansion from the water heater. But if you have a check valve or back flow preventer, you will need a small thermal expansion tank, and I would also add a pressure relief valve.
Be sure and mark where any underground connections are, as it is hard to find them after they start leaking.
