Poly pipe will expand or contract by 1" for every 10 degree temp change for every 100' of pipe. If you have 20 degree change in ground temp between summer and winter, 2500' of pipe will expand and contract by 50". Be sure and fuse weld the connections as it will pull apart from compression couplings. And concrete thrust block or anchor the ends of the line.
In summer the pipe expands 50" and pushes up in the ditch. Rain will pack the dirt under the pipe. Then during winter when the pipe contracts 50", it will pull loose from the connections.
PVC pipe doesn't expand or contract nearly as much, and gasket fittings leave some room for expanding and contracting.
