very confused
EllenLG
could some one please tell me what the difference is between americast and cast iron?
Gary Swart
Yakima, WA
:eek: Apparently the name "Americast" is also applied to a man made material used for sinks and tubs. My first search produced the results that I gave in my first answer. What little information I could find on the tubs and sinks indicated it is much softer than cast iron and therefore has some problems.
Master Plumber Mark
www.weilhammerplumbing.com
americast...
What I have ben told abot Americast is that is is a
Polymer that is sprayed into a Steel Tub to make it seem like cast Iron
they are much lighter so they get usede quite a bit and will last for about
5 --10 years before looking totallly worn out...and frazzled in the bottom
and they seem to discolor or fade over time
I have never liked them becasue they still chip just like the tin ones....
The americast kitchen sinks work OK but still can chip...
I prefer the Sterling tubs over these...
Jimbo
San Diego, CA
Americast is American Standard's brand name for a tpye of fixture now made by several companies. The body is a molded polymer material; the surace has a very thin metal layer,over which the porcelain finish is applied. They have the rigidity of cast iron, claim to have the same durability. Supposedly do NOT chip easily like the steel tubs and sinks can. For a tub, they hold the heat much better than cast iron.
These have been around for several years. I have not heard any negative reports. Price wise, similar to cast iron. Because they weigh so much less, your back will love you for that.
