Vertical DWV PVC pipe support
Dohc
Wisconsin
I have a short (about 12") 2" vertical PVC drain pipe that comes out of a shower floor drain and then goes into the P-trap, view from below...
y4mOKpv7l_U4_4HTb3hkmezt6iTJ7elsKPpqziJjfnoGntC9kS_IELb-XhAj9WxV3-tUp-unHTiMTBhq-r8BrePI7sUf4-K7g18uqn_6FQb-ExGPgYYwsgAP2VwDo4T4fvVe6MYYACH7FP-Nrs0UrD-AKttPUesgJW_l_Y-thk-5oYIVQ_CEQKLXJTX4E8UY8xs
View from above with shower pan and 2" PVC installed...
y4m2PcYZf3KYake4YrY4mPa92gEoTB13koF8cktlvtK4wUKALJplOJUCyl6h8-srz7Jb63pmbfTp2u3fOBi6rOxaQXKWxv22E5zdRFihSItRy_lDVVJutY_3o6IFQQ8wbCuiFUty_qc3We7OF9DwOyNIKQd7gGbSB_aONn5S_xbULoJ1N1BULdXnwTEtoC1PiUR
The shower floor drain is a wedi/Sioux Chief assembly...
y4mAviXCsa2d5oXMPFBN8dz02aXOAfhtihvei-9XMnrWwfpuI9eucPwSty0L0pAoH8WmJet-JT9i9F7PLBm-e2KiRParHzxVTNw6UfwafsDVvuSKKlg0b6X6cH52PU96oBxMYhmwG3vSyZqny4m9ZLc1grMEWzYgJuOhWOyGaLezkeRkhz4isXNU8oIdkck_oOp
I would like to firmly and securely support this short section of vertical 2" PVC pipe which will be concealed below the subfloor, to ensure no movement. What is the proper clamp or method in securing vertical DWV PVC?
"Riser clamp", and then do some support of the wings of that.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Exact spacer (we carry many scraps of various thickness), then wrap with 20 mil tape and two hole galvanized pipe strap.
Frankly, I would only expanding-foam in the horizontal portion and call it good.
Dohc
Wisconsin
Thanks for the feed back. I ended up putting blocking behind the pipe and then "clamping" with metal strapping.
y4mA74eCYNZ-Zho7wtL9YOUCWxyoOd6eXuG0tbdSTdR6pdpiswbXv-2YbvOMXb-pQROBFIg3EP4E2IBcu4uTaYfgxjnmzTkkazKV6YQpzZPM17woChKCjgD8ZvuEnrTy97VS_K2PqLbBr1h8p7Ge_eY6fdRsucqvoOt62jd8x0uo7wMaNzE7lsR8weW81jlvGO1
Did the tub the same way...
y4m6dU5OpKz02Ickl4wFzWK-8Osj7WDtKrH2aYSQDagITMZe5JrZc2DmmDcqXnfA4RLAMUVJ1KvFYAiULqJNIjZ3i4-_zsI8xzT3QcdewXa77oMm4lzyPbjxImwpW2RNslwek-oFlQePs27mUhBVlb5_iqKauQtsnjFEjzDIDlqsZSDo05KdAPrpViSyY0i3UWo
Pipe is solid now.
