Sewer Pipe Repair
Bvs999
Houston, Tx
Hi All,
I am remodeling my kitchen and when the contractor pulled off my old cabinets, I noticed there was a screw in a vertical drain pipe running from the second floor to first floor that drains a sink and HVAC condensate. Long story short, he did not call a plumber to fix it, but used a slide coupling that would be used for something like a sprinkler fix, similar to the below link.
I know this is not right, but:
1. Will it work, or will it clog or leak over time
2. If the right way is to open the drywall back up, should he use a Fernco and if so, which kind? Classic rubber, no hub or a shielded coupling
Thanks in advance
WorthFlorida
Solutions
Orlando, Florida
Michael Young
North Carolina
Hi All,
Thanks in advance
If I was going to dig into it, I would use a heavy duty no-hub band.
But you're saying it's just a nail hole. To install a no-hub band, you're going to have to cut the pipe to get the no-hub around the pipe. CUT PIPE vs. tiny nail hole... If I was my own house, I might just patch that shit with some 2-part epoxy if the rest of the pipe is in good condition. trust me, the 2-part epoxy will last longer than you.
Tuttles Revenge
It does need to be replaced. That telescoping fitting is likely an obstruction that will catch material and clog up. A couple appropriately sized shielded couplings and pipe would do the trick since you have to cut out that extendo coupling now.
I would remove the nail or screw, and only then apply one of the suggested fixes. Or in the case of a screw, maybe cut/grind off all but one pipe thickness of the screw shaft, and put the shortened screw back.
Tuttles Revenge
During an inspection I found a hole in a vent pipe where it looked like someone shot a nail through the pipe mid stud bay. Water was geysering out. I was going to cut it and couple it, but my inspector found a chunk of wood, whittled a wedge and hammered it in til it stopped leaking and wiped ABS glue over it.. "Done" he exclaimed..
Michael Young
North Carolina
hell yeah. best inspector ever.
