Vertical adapter bolts
catldavis
Florida
Wondering what to do about the bolts on my adapter. One is fine, one looks like it was replaced with a longer bolt and nut and one appears to be broken off in the adapter. Would you just replace the bolts with new adapter bolts (if I can find them), new bolt/washer/nuts or replace the adapter with a new adapter?
[/url] [/IMG]
Sylvan
Still learning
New York
Wire Brush adapter and use stainless steel bolts and new gasket
catldavis
Florida
Thanks for the reply. Do you know where to get the adapter gasket? Can't seem to find just the gasket online.
Fitter30
Peace valley missouri
Call a plumbing supply wholesaler or possible hydraulic hose repair. They should stock red rubber or garlock gasket material or the gasket itself. Flange gasket might work.
Sylvan
Still learning
New York
I posted Rainbow (red rubber) before they use it I think knowing what is flowing through the pipe should be known
Rainbow Rubber Extrusions, Inc. is located in Barberton, Ohio in the USA. ... Rainbow Rubber Extrusions has been manufacturing quality Viton® products since 1984. Viton™ is the most specified Fluoroelastomer rubber for fuel system seals, hoses, o-rings, and gaskets as well as many other uses.
I think before he orders anything it would be a great idea to know what is flowing through the pipe and the temperature
There is only well water flowing through the pipe, other than a little chlorine for occasional sanitizing. This device runs water down a 2-inch pipe to a venturi, and water comes up an inner pipe at elevated flow rate.
index.php
Sylvan
Still learning
New York
There is only well water flowing through the pipe, other than a little chlorine for occasional sanitizing. This device runs water down a 2-inch pipe to a venturi, and water comes up an inner pipe at elevated pressure.
index.php
Thank you every day I try to learn something new
