I have a booster pump system ( pump / tank/ pressure switch ) and an instant gas boiler for hot water supply.
At the shower , the water temperature keeps changing between the pump start and stop because of the pressure fluctuation between the cut in and cut out pressure values .
I also have to keep min hot tap opening otherwise the instant gas boiler would turn off if water pressure passing through it is not enough
Any ideas of how to have steady pressure and consequently constant shower water temperature?
Thanks to every body in advance
