greenalfonzo
Hi,
I just noticed that my sprinklers weren't coming on, so I looked and the display on my irritrol RD600 was blinking the accurate time. I adjusted the start time, and found that the water wasn't flowing when the system turned on. I then tried maually activating different valves through the control box without results.
I then opened the box, and opened the the little plastic bleeder screws and the sprinklers all came on. I then switched the solenoids to different valves, and repeated the process getting the same results. I checked the solenoid & the hole under it and they seemed clean and functional. No water flow through any valve, and a lot of clicking from the solenoid on the new first run valve. Trying to run a different zone manually through the box just has the display flick to a flashing OFF.
Thanks for any advice with this one.
