Utility sink/water softener discharge.
crtbilly
Maryland
Hello all,
I wanted to move a utility sink in my basement to a new location. Attached is the picture of the pipe i would tie into. It currently services a kitchen sink and a dishwasher and is vented at the sink to the roof. I was planning on using an AAV but not 100% sure it is necessary if i do like the image below.
Should i also put a cleanout in this line or is that also unnecessary.
Non-Baltimore MD is IPC. Yes, you need an AAV for this project. Will you also be adding a standpipe, or just have the laundry sink?
I don't know if a cleanout is required, but it will be a good idea.
crtbilly
Maryland
Thanks Reach! I really appreciate you taking the time.
I do plan on adding a standpipe. I have a water softener and a condensation pipe from a hot water heater. Was gonna do it just like its picture above plus the AAV.
oh, not sure if you saw in my drawing the red line i drew? Sorry for the horrible picture. That was supposed to be a vent stack, but i guess it would have to run all the way back to the main vent?
So if I run the AVV, I don't have to worry any other venting.
I saw the red line, but it is not what you are going to do. To run a vent from above, you would have to tap in 6 inches above the flood level of fixtures in the kitchen.
Instead you will run an AAV. There are two 2-inch santees-- one on its back below the AAV.
Also, either santee can be a combo. I also did not put in a cleanout. That could be a wye above the drain fitting, or could be a 2-way cleanout, etc. The blockage under a kitchen usually happens below the basement floor, where the flow transitions from vertical to horizontal. A cleanout to let you run a snake there would be good.
crtbilly
Maryland
Could I use something like this?
3" PVC DWV Sanitary Tee w/ 2"Right Side Inlet​
PVC DWV Spigot x FIPT Cleanout Adaptor with Plug​
