Use of 90 Degree Elbow (not vent elbow) for Vertical to Horizontal Drain
emazz1
Need some advice for a first time DIY plumber here.
I'm roughing in drains for a double vanity. I'm using 1.5" drains from each traveling horizontal in the wall to meet a 1.5" vertical drain, with a vent going up from that. The bathroom has a 3" waste pipe that runs perpendicular to the vertical lav drain pipe, but is not directly below it. Can I use a 90 degree elbow or a 90 degree long sweep at he bottom of the vertical drain to then tie into a wye I'm adding to the 3" waste pipe?
Staring at the sink wall, the vertical drain would hit the 90 degree elbow and come straight out towards you, and then tie into the 3" waste pipe. Is the 90 appropriate?
Breplum
Licensed plumbing contractor
San Francisco Bay Area
For vertical to horizontal drainage, a long sweep 90 IS the fitting to use.
When more than one lav drain, two inch pipe should handle the combined load. Inch and a half is fine for combined vents.
When horiz. drain connects to vertical, a Tee fitting is used. Unnecessary to use a WYE.
emazz1
Thanks breplum. So if I have a lav sink on each side of the vertical drain, I would use a double sanitary tee to meet in the middle, with my vent going up, correct? Also, after I use the long sweep 90 to transition from vertical to horizontal, does it matter if I use a wye or a long sweep to tie into my 3" horizontal drain pipe?
Tuttles Revenge
A wye or Combination wye&1/8th bend / Long sweep tee (as the box stores call them) are both appropriate. The combi is a wye with a 45 to make it the long sweep.
