Dorlando13
Hello, I am needing to reroute my downspout. I plan on connecting it to a pvc adapted and then running pvc away from my house but I need to make two 90 degree turns. The downspout will drain into a pvc adapter and from there it will make a 90 degree turn for a couple of inches or so. I then need to make another 90 turn to take the pipe to the discharge location.
Would I be ok using 90's or do I someone need to use 45 degree elbows. In the picture I am going to run the pipe along the wall behind my pool equipment. So you can see that I need to make a turn off the vertical downspout and then another turn to go behind the equipment.
If I use two 90's will the water back up? Thanks
