Use multi san-tee for drainage with top inlet plugged?
wwhitney
Berkeley, CA
Say I have a set of horizontal drains (already vented) converging towards a single location and I want to combine them and turn downward into a single vertical drain.
If it's just two drains approaching from opposite directions, I could use a double quarter bend. But suppose it's a different configuration (two drains approaching at right angles, or three drains). And suppose I have a single or double san-tee with the appropriate sanitary side inlets (not straight). Is there anything wrong with using the san-tee to connect all the drains, and just plugging the unused top inlet?
I can't think of any code issue, but I'm not familiar with all the code sections.
Cheers, Wayne
James Henry
Billings, Montana.
I've never seen it, probably for the same reason you don't use a double santee on back to back lavatories, the drain snake will go straight through to the other side and not down the stack. A double wye may be a different story, but I'm not a code official so I can't say.
Might be better if you could run a cleanout into that top inlet. That way a snake from the side is not needed to rod on down.
wwhitney
Berkeley, CA
That is a practical suggestion if the cleanout would be accessible or easily run to an accessible location.
For the case of a single san-tee with a sanitary side inlet, snaking shouldn't be a problem. Would a double quarter bend have the same snaking issue as a double san-tee?
Obviously wyes would be better, so this question is of practical use only for the case that the required configuration can't be achieved with wyes in the space available.
Cheers, Wayne
James Henry
Billings, Montana.
I've snaked more than a few drains that were connected by double santee and almost always came out the other side, the last one were two restrooms connected in the middle with a santee and the snake ended up coming up in the other toilet. A side in let tee is different because the drains are at right angles to each other. Good luck.
