Smart Tee Questions
I am trying to figure out what the Smart Tee does and how it permits use of a smaller pressure tank.
The Smart Tee seems to include the following design and operating features:
1. There is a regulator in the inlet of the line from the pump, between the pump and the pressure switch, relief valve, and system.
2. The regulator appears to connect the pump directly to the pressure tank, and allows the tank to be pressurized to a pressure higher than the setting of the pressure switch as long as the system demand is great enough to pull the pressure on the system side of the regulator to below the switch cutoff setting.
3. If the system demand is shut off quickly, it appears to be possible that the tank pressure will be greater than the switch cutoff setting. Is there an internal control that prevents that higher tank pressure from being transmitted to the system downstream of the regulator through the passage that allows the pressure at the pressure switch to be higher than the regulator setting?
4. How does the relief valve on the downstream side of the regulator protect the pressure tank under flow conditions where the tank pressure is higher than the pressure switch setting? Is there some kind of bypass that bypasses the regulator so that the higher tank pressure will actuate the relief valve, and also expose the system to pressure higher than the pressure switch setting under possible operating conditions?
How would the result with the Smart Tee be different than putting a regulator on the down stream side and setting the shutoff of the pressure switch 10 psi higher than you would set it without the regulator? And what percentage smaller pressure tank is permitted with the Smart Tee?
What is the maximum pressure, above the pressure switch setting, that the tank could be pressurized to under worst case operating conditions?
