I know this is very stupid but holes were drilled accidentally in the drain elbow...the tub is on slab and the PVC pipe the leads to the drain is cemented in...removing the tub to fix this is not an option. Is it possible to put JB Water Weld in the holes and then put another circular piece of PVC or plastic on top for that and then seal it so water doesn't get in there? Thank you.
