Transition from horizontal to vertical drain
JAFI
Richmond, VA
I'm running a new below the basement floor drain to replace an old galvanized drain pipe that came up through the floor. The drain line I want to run is perpendicular to the basement wall. I would like to run the new line up to the wall and then straight up the wall using a 90 fitting. What I can't figure out is how to make the vertical run up the wall (Plumb) when the horizontal run is pitched 1/4' in 12". When I test fit it with a long sweep 90, the pipe pitches away from the wall instead of plumb (same 1/4" in 12" out of plumb). I'm sure plumber encounter this situation all the time. Any help would be appreciated.
James Henry
Billings, Montana.
When you glue the 90 on the horizontal drain, (if it is PVC). Put a torpedo level on top of the fitting and level it left to right and front to back, even though the fitting won't be perfectly bottomed out on the pipe its insignificant.
That is vertical to horizontal, and that calls for a long sweep.
Putting in a cleanout on the vertical is a good idea usually-- especially if the pipe will carry kitchen waste.
JAFI
Richmond, VA
Thanks, yes its 2" PVC, so there should be enough play in the fitting to correct for the fact that the horizontal pipe is pitched and I don't want that pitch to transmit to the vertical riser.
I have heard some say the long sweep may really be a 92 degree, but I never checked. More likely things are flexible enough to give you your 2 degrees.
JAFI
Richmond, VA
I already glued the horizontal piece to the long 90 last night. The horizontal run is in a trench below the basement floor. Any tricks for holding the pitch of the horizontal run in the trench while I try to glue the vertical a little offset in the fitting?
Bags of sand and concrete on top of the pipe, and pieces of wood below?
