JAFI
I'm running a new below the basement floor drain to replace an old galvanized drain pipe that came up through the floor. The drain line I want to run is perpendicular to the basement wall. I would like to run the new line up to the wall and then straight up the wall using a 90 fitting. What I can't figure out is how to make the vertical run up the wall (Plumb) when the horizontal run is pitched 1/4' in 12". When I test fit it with a long sweep 90, the pipe pitches away from the wall instead of plumb (same 1/4" in 12" out of plumb). I'm sure plumber encounter this situation all the time. Any help would be appreciated.
