TOTO Water Hammer
Discussion in 'Toilet Forum discussions' started by JoeRI, Feb 17, 2020.
  1. JoeRI
    JoeRI New Member
    Feb 17, 2020
    Rhode Island
    Hello,
    I recently purchased and installed a new Toto Promenade II after a bathroom update. The previous toilet was 15 y/o Mansfield.
    I love the Toto. However, I notice that the fill valve closes much faster than the previous toilet. Because of this, I am getting a slight water hammer (I hesitate to call it a true water hammer, its more like a slight vibration). This did not happen with the previous toilet and I have not changed the existing shut off (it was in great shape).
    I called Toto. Their advise was to close the shutoff slightly (like 3/4 open). Sounds like a bad idea to me. Any other options beside changing the fill valve?
    Also, I see that they make mini hammer arrestors for the supply line. Has anybody used one? If so, how do you like it?
    Also, if it matters, we are on well water. I do get a hammer on our front load washing machine (i have installed mini arrestors here to get rid of the problem).
  2. Sylvan
    Sylvan Still learning
    Sep 23, 2004
    plumbing - fire suppression - boiler inspector
    New York
    Toto is correct
    The supply valve to most fixtures is a globe pattern type and the reason being a globe valve is designed for throttling
  4. JoeRI
    JoeRI New Member
    Feb 17, 2020
    Rhode Island
    I have a quarter turn ball stop i believe. Its by brasscraft. Does that make any difference?
  5. Terry
    Aug 17, 2004
    A 1/4 turn will also throttle down. I would play with it and see what happens.
  6. JoeRI
    JoeRI New Member
    Feb 17, 2020
    Rhode Island
    Ok. I will start with the shut off.
    If that doesnt work, has anybody had luck with the mini arrestor on the supply line?
Similar Threads: TOTO Water
Toilet Forum discussions Dynamax Toto toilets small water spot will be a problem? Jan 10, 2020
Toilet Forum discussions 1,500gal per day water usage -- Toto Emax 528 running constantly Aug 13, 2019
Toilet Forum discussions Toto Drake 1.6 Gal Water Hammer May 5, 2019
Toilet Forum discussions Toto Drake 1.6gpf flush valve causes water hammer Jan 5, 2019
Toilet Forum discussions Toto Ultramax - water flowing/dropping sound after filling tank Apr 9, 2018
