Steven A
I am replacing the toilet in a 96 year old home, and going with Unifit to make the best use of space with the 15" rough in that I have to work with. But before I buy the toilet I'd like to make really sure that there won't be clearance issues with my water supply. It comes up from the floor and at its edge it is just barely 5.5" away from the center-line of the floor flange. In your helpful breakdown of the Unifit line it looks like that spacing will work with our preferred model, the Guinevere. https://terrylove.com/wc/unifit.htm
But that description may refer only to water supplies in the wall and not the floor. Does that matter?
Also, is there any wiggle room? My spacing is tight! I'm going to have to measure again with big carpenter squares or something to be sure I have the correct center-line.
Finally, according to these drawings it seems that the Vespin/Carlyle has a base that is 7/16" narrower than the Guinevere. Do you think that would make the difference?
https://terrylove.com/pdf/ms974224cefg.pdf
https://terrylove.com/pdf/ms614114cefg_spec.pdf
Thanks for the help!
Here is a picture (disregard the handle for the old hot and cold lines - that old plumbing has been replaced and I'll be moving the handle to the other valve - preserving some decorative history):
