Hi,
i've had my Toto toilet for about a year now and I'm noticing a couple of issues. They are most probably related but I'm no expert or for that matter a novice either.
Basically my toilet will run constantly because after flushing the stopper will not cover the hole completely. When i make the slight adjustment by hand it stops running, which makes sense. However, sometimes the tank wont re-fill after flushing and the bowl wont flush but has a constant drain. The water continuously runs but the tank does not fill up. I figure its just running straight through the tank through the bowl and then down the drain. I can not stop this action and am forced to shut off the water supply. After a few minutes wiht the water turned off it returns to normal function.
I'm sure i can adjust the stopper or get a new stopper to cover the hole and that should deal with the first problem, but i think i have a much larger issue with the fill valve and the internal workings.
Any idea of what i should do? It's kind of annoying when your toilet works correctly only 10% of the time.
thanks in advance for your responses.
