Toto Drake flushing issue (ie not flushing)
Discussion in 'Toilet Forum discussions' started by JMac, Jun 13, 2021.
  1. JMac
    JMac Member
    Dec 29, 2014
    Florida
    A little background. The bathroom is on an exterior wall, and from that wall goes bathtub, toilet, then a single-sink vanity. On the opposite side of that interior wall is the kitchen double sink. The house is a 3/1 ranch on a slab built in early 70s with a septic tank a few feet outside of the bathroom/kitchen wall area. The tank was last pumped about 4 years ago. For most of those 4 years, there have been 3 adults living here. I just had a reroof job which also involved work around the vent pipes.
    In the last couple of weeks or so, 9 times out of 10 the toilet will not completely flush on its own, even when purely liquid. Using a plunger will generally work the first time, but sometimes it takes even another flush using the plunger to get it to completely flush. So when you flush, the clean water swirls into the bowl like normal, but will then slowly drain. Not super slow; about a minute or so and then the water level in the bowl is back to its normal level.
    None of the sinks nor the tub have a noticeable slow drain, only the toilet. The toilet does drain, but doesn't usually flush. So where should I start? Pump the tank? Look for an issue with the vent pipe? Replace the toilet? Move?
    TIA. James
  2. Terry
    Aug 17, 2004
    I would check the jet way at the bottom of the bowl to make sure the siphon is working. That kick starts the siphon. If that gets plugged up, then flushing is a problem.
    Also, anything in the trapway can slow the siphon. Sometimes a closet auger to clear what be there in the traway.
Similar Threads: Toto Drake
Toilet Forum discussions Toto Drake CST746 washdown fill tube? Tuesday at 9:04 PM
Toilet Forum discussions Toto Drake MS786124CEFG a Washlet+ toilet? Sep 11, 2021
Toilet Forum discussions Toto Drake II (CST454CEFG#01) vs American Standard Champion 4 (2034.314.020) Jul 14, 2021
Toilet Forum discussions Toto Drake Install Jun 30, 2021
Toilet Forum discussions Toto Drake Hissing Jun 20, 2021
