Toto Drake CST744 hard to flush and tower sticks open.
Nutley
New Jersery
Been having this problem since the toilet was put in a month ago.
The flush lever takes a lot of force to push down and the tower does not drop down all the way to seal after flushing. It stays slightly up, the tank lid has to be taken off and the tower has been to pushed back down to seat itself again. Any ideas on why this is happening and how I can fix it?
The trip lever rod is brass. Have you tried bending it to make it pull up and down in a more aligned way?
Nutley
New Jersery
I have not, I will look at that today. I spoke with Toto and they said the pins may not be lining up.
thetwins
California
I have this exact same issue! I tried manually seating and reseating the tower up and down multiple times, in case there was friction keeping the tower from falling into the correct position, but it doesn't seem to have helped. Has anyone found a solution? This is so frustrating! This toilet is practically brand new, as it is used approximately once a month.
The tower will rotate all the way out and will rotate back in again. You can check the seal at the bottom while out. Making sure the brass rod pulls straight up helps.
thetwins
California
Thank you Terry! So I finally followed your suggestions and took out the tower (moving totally fine when not sitting in the tank) and bent the brass flush rod forwards to try and straighten it. It’s much better now, and only occasionally sticks. When it does, I re-flush until I hear the ‘thunk’ that means it is seated correctly. Also, I can tell immediately after initial flush now - if the water does not fill the bowl rapidly, then it’s fine. When the water fills the entire bowl immediately, then the valve is stuck open and needs work.
Again, not perfect, but MUCH better than having to lift up the tank lid after every single flush to push down the center of the tower. Thanks again!
