Toilet is difficult to flush
imaginethat
Tulsa, OK
My toilet takes 4 times to flush even with just urine and no toilet paper. The plumber took off the toilet and cleaned the line. He says if that doesn't work I could try getting a new non low flow toilet.
It's a Western brand toilet, only 5 years old. I'm the only one using it so I know nothing has fallen in. The other Western toilet in my house works fine.
Is this really my only alternative?
Fitter30
Peace valley missouri
Pour 4- 5 gallons of water in the bowl fast see how it flushes. That will tell you if the problems piping or tank and the holes under the lip.
Peterson
Active Member
PA
Maybe the siphon jet at the bottom of the bowl is plugged up with lime/minerals? If that happens, many toilets will not siphon out. Take a small screw driver and poke around in the jet and scrape out any minerals that might have built up in there.
BECplumbing
Plumbing Apprentice
Louisiana
The siphon jet could be clogged up. You need to take a small screwdriver or a coat hanger and poke around the jet and unclog it.
