pamplemouse
On the side of my toilet there is an inlet to access the sewage pipe if blocked. Lately, when I flash the toilet the water rises up to the ream in the bowl and slowly goes down like if there is a blockage. I purchased a hand held eel from Bunnings and inserted the 7,5m long eel in the inlet on the side of the bowl.
When I flushed the toilet with the outlet open to air, the water evacuates normally but if I seal the outlet the water raises up again to the ream and slowly goes down. Also when the outlet is open there is a big gasp of air coming out of this outlet while the water flashes down and then after few seconds a kind of blob like a air bubble coming up to the surface.
Do I have a blockage along the sewage pipe? And if so, why does it flush without problem when the side outlet is open to air?
Any help would be appreciated.
